MXDPERFSTAT utility not generating the output
1260
06-17-2012 07:26 PM
AntonyPaul_M1
I was trying to generate mxdperfstat utility on a mxd. The utility is working fine its opening the Arcengine intefacing analysing to different scales. I can also the see it in the command prompt utility.
But at the end I don't have anything as output?
Do anyone help on this?
Cheers
Antony
nicogis
haven't a xml file created (mxdperfstat_Namemxd_YearMonthDay_HourMinute_Seconds.xml)?
In log (mxdperfstat.log) have you an error?
