Mosaic to New Raster gives different values
2708
08-29-2012 07:42 AM
AlisaMorrison
I am mosaicking several rasters to a new raster and when completed, the new mosaicked raster has different values than the original rasters.  Any suggestions?
TimothyHales
Esri Notable Contributor
Are these single band or 3 band imagery?  What is the pixel type and bit depths of the input rasters and the output raster?  Are you comparing the range or the individual pixels?  How far off are the values?
AlisaMorrison
They are single band with continuous signed integers.  (32 bit) The values are off by random amouts varying from being exactly the same to being off by more than double.  I'm calculating solar radiation and starting with values like 250,000 so here are some examples. (value of original raster, value of mosaicked raster)
(140936,126618)
(271121,261405)
(93114,176000)
(124012,134030)
(177773,126547)
(123345,241540)
I've also tried changing the NoData values to 0 and that didn't work either.  I"m at my wits end.
EricRice
Esri Alum
Hi Alisa,
Do the rasters all have the same underlying grid?  In other words, do the rasters that are going into the mosaic, all have perfect cell alignment?  If they don't you should expect the value to change somewhat because they will be resampled.  What resampling do you have set in your environments?  Also, is there any overlap between the inputs?  What options were set in the Mosaic Operator parameter?
If you have support, you should open an incident so an analyst can have a look.
Best,
Eric
AlisaMorrison
Hi Alisa,
Best,
Eric
Hi Eric,
All the rasters have the same underlying grid and the same cell alignment, they do not overlap at all.  I tried all the different mosaic options and have given up.  I have tried everything I can think of to make this work and I think there is some bug in the program.
EricRice
Esri Alum
What version?  Support is the best option at this point.  They can get your data to repro the issue and submit a defect.
Best,
Eric
