mosaic dataset add raster duplicates?
1769
07-25-2011 09:38 AM
gisscconsulting
This ESRI code snipple shows how to add raster to mosaic dataset
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_add_rasters_to_a...
However, it won't consider exist ones. If you run the method the second time, duplicate records added.
There is "AddNewRasters" in IMosaicDatasetOperation interface
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//001q0000018r000000
However, the documents related to that is none.
Any one have successfully used this "AddNewRasters" method in .net?
Are there a way to remove an item from mosatc dataset using .net?
RobertBerger
Greetings,
To exclude duplicates on load you need to set the property in IAddRasterParameters:
IAddRastersParameters AddRastersArgs = new AddRastersParametersClass();
... setup crawler etc...
// Exclude duplicates
AddRastersArgs.DuplicateItemsAction = esriDuplicateItemsAction.esriDuplicateItemsExclude;
Hope this helps.
Robert
gisscconsulting
It worked just as it said. Thank you
