merging small polygons with the biggest adjacent one
20524
03-14-2013 01:42 PM
AnaOrtega
Hello,
I have a polygon shapefile with almost 100,000 records, around 80,000 are small polygons that i'd like to merge to the biggest polygon adjacent to each one of them. I can't use dissolve cause i need the little polygons to change their attributes to the largest nearest one.
Obviously i'm looking for an automatic solution, otherwise it would take me months of selecting each small polygon and then dissolving it with the nearest one by hand.
Any ideas?
Greetings,
Ana
MelanieSummers
Hi Ana,
Are your large polygons and small polygons in the same feature class?
Best,
Melanie S.
MelanieSummers
Hi Ana,
As long as the polygons are touching, you could use the Eliminate tool if you have ArcInfo.
Best,
Melanie S.
AnaOrtega
Hi Melanie,
Thanks for your reply, yeah, my polygons are in the same future class.
And unfortunately i dont have ArcInfo, but i'll check if i can use the Eliminate tool in ArcEditor. Just check the link you left and seems that it's just what i need. Now only to solve the "little detail" of ArcInfo licensing.
Thanks a lot!!
Ana T.
AnaOrtega
Hi Ana,
Best,
Melanie S.
DONE! I used one of my workmate's ArcInfo 😄 thanks a lot for your reply, it really made my work easier
JohnSobetzer
Honored Contributor
