Merging Annotation files
1195
05-08-2014 05:37 AM
EmmanuelJohn1
We are converting Annotation files from CAD by Using Import CAD Annotation tool, the plan is to create a single file in GIS from all  CAD annotation files. Since there are a lot of CAD sheets all of them cannot be Imported in a single Output dataset. Next step is to  Merge these annotation files that are converted from CAD. When I merge them the necessary fields become null, they are necessary  because they hold Attributes that show up stuff on the map. I cannot Join the data afterwards because there is not a common field  to join with. What can I do to prevent the null attributes to appear when I merge the annotation files??
PaulLohr
Have you tried the Append tool?
Might have to rework your process since you'll need a feature class as the append target.
Paul Lohr
Lohr Geospatial Services, Inc.
EmmanuelJohn1
Trying it out now seems like its working
