Measurement is meter square
1389
12-12-2017 12:23 PM
xxxlll
Hello everyone.
In this sample code can I measure the area of the selected area as Meter square. It is given in acres .
var area = geometryEngine.geodesicArea(polygon, "acres");
if (area < 0) {
   var simplifiedPolygon = geometryEngine.simplify(polygon);
   if (simplifiedPolygon) {
      area = geometryEngine.geodesicArea(simplifiedPolygon, "acres");
DanPatterson_Retired
anything geodesic I am sure you can specify the coordinates.  Perhaps it is in acres because the projection uses feet for coordinates.  What does the documentation for that method show?
ModyBuchbinder
Hi
Check this doc: geometryEngine | API Reference | ArcGIS API for JavaScript 4.5
Use square-meters as paramater
