Layer View Error
1206
05-06-2013 08:48 AM
User35489
Dear All,
In ArcCatalog, a layer in geodatabase, shows the table but when i switch to geography option it shows nothing. I tried to open that layer in ArcMap it gives out below error
"Warning, Inconsistent extent
One or more of the added layers has an extent that is not consistent with the assosciated spatial reference information. Reprojecting the data in such a layer may lead to unexpected behaviour. Use ArcCatalog to confirm the spatial reference is correct and adjust if necessary"
When i checked sde logs, i found error
"Load_buffer error -51 on layername, rowid -1"
Previous day it was working fine.
Environment: RHEL 5, Oracle 11.2.0.2.0, ArcSDE 9.3 SP1
Please look into this issue.
-Abdullah
EmadAl-Mousa
two things:
check your spatial index (rebuild it or delete and re-create it).
also, the error is showing an issue regarding your coordinate system, if this feature class is under a feature data-set it should be within the same projection.
Regards,
