Layer not align, HELP!
4527
12
06-05-2014 04:14 AM
TeikKeanTan
I am new in ArcMap. I got a shapefile and a layer file.
I open it in ArcMap and try to align both layer. But both the layer didn't align properly.
Both coordinate system are the same.
Is anyone can help me on this? Greatly Appreciated!
AndyJones
I think the shapefile you have has a .prj file. Try renaming it, then repeating the steps. The data you uploaded didn't include a .prj file, so the shapefile that I was using had no coordinate system.
Whatever coordinate system is in that prj file isn't correct.
Melita
Quite amazing that this thread has replies from someone at esri and it has nothing to do with geocoding. When a question that actually relates to geocoding appears, esri staff are nowhere to be seen.
TeikKeanTan
Perfect!
Get it done finally.... Thanks a lot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MelitaKennedy
Esri Notable Contributor
I noticed the post in the "New Posts" list and didn't even notice which forum it was in!
From what I know, the forums have always been designed for user-to-user help, not a replacement for Esri technical support. Some Esri employees read the forums, a lot don't.
Melita
