LAS dataset RGB value
3726
02-05-2013 03:43 AM
M_J_Glasbergen
I've got a LAS 1.2 dataset with embedded RGB values. On the internet there are nicely colored pictures of LAS datasets with their RGB values, but I can't figure out how to get the RGB value as a LAS attribute. The LAS File Properties and Statistics show there is an embedded RGB value (Has RGB: YES), but the LAS attributes shown when selecting LAS attribute grouped with unique symbol don't show RGB as an attribute. Any idea how to get the points colored by the embedded RGB value? THNX
M_J_Glasbergen
Hmm, it seems that in ArcMap there is no possibility to use the RGB value, in ArcScene the same LAS dataset does show RGB as an attribute. The next challenge will be to set the point size...
