jsde*.jar files for WFS connection to ArcSDE
1092
06-25-2012 12:45 PM
MattSimmons
This probably applies to the OGC forum too, and I'll post there as well.
I've successfully created a WFS from an open source stack to connect to my ArcSDE 92 on Oracle 10g instance by utilizing the jsde92_sdk.jar and jpe92_sdk.jar files.
I now need to do the same thing for my new ArcSDE 10.1 on Oracle 11g instance.  I cannot find these two files on my ArcSDE installation location.  Where are they?  Or, can I just use copies of the files I've already got?  Or should I expect to see a jsde101_sdk.jar file?
VinceAngelo
Esri Esteemed Contributor
If you're going to use the ArcSDE Java API, you should use the jarfiles installed by the SDK media kit
that matches your release.  For the past few releases you've needed to request the 'C' and Java API
media kit through Customer Service (not available for web download).
- V
