Is the Oracle database is faster than SQL database?
5361
10
06-04-2013 08:51 AM
JamalNUMAN
Legendary Contributor
I have a performance issue in my web mapping application and wanted to investigate multiple factors that might affect the speed:
�?� Hardware specs of the host and client machines (CPU and RAM)
�?� Cables connecting host and client machines (vpn, leased lines, etc.)
�?� ArcGIS server Tuning (min/max instances, high/low isolation, cashing, etc)
�?� Database (personal geodatabase/file geodatabase/ ArcSDE geodatabase with SQL or Oracle, etc.)
�?� Web mapping application (ADF, Silverlight, Flex)
In this thread just I wanted to know if there might a definite answer whether the Oracle database is much faster than the SQL. For the time being, I�??m using SQL server database and I�??m struggling with the performance issue as the source data for the URLs used in the web mapping applications is the SQL server database
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
Different sports cars may take a winding mountain road in slightly different times, but a
tractor-trailer won't ever give them competition.  Still, the sports cars aren't going to
score well on the basis of tons of food delivered.  As a technologist, you need to learn
how to gauge the similarities and differences of competing software packages, and use
that as feedback into generating unbiased evaluation criteria.
- V
Many thanks Vince. I do agree.
Best
Jamal
Jamal Numan
