Is it possible to batch delete raster statistics?
1435
10-31-2011 06:04 AM
VinceLegendre
Does anyone know of a way to batch delete raster statistics like their is to batch create statistics?
Vince
VinceLegendre
What I ended up doing was deleting the tif.aux.aml file associated with each image. That was where the information for the raster statistics was stored.
SusanJones
Copy and paste into Python file, update the directory variable in the code and run. All aux will be removed in the folder and subFolders.
#smjRemoveStatisticsFromFileImagery.py
#Purpose:
#Remove image statistics from file-based imagert
#import Modules
import string, os, datetime, sys
#banner
print "***\nRemove Image Statistics from Directory and Subdirectories\n***"
#input Parameters
#USER NEEDS TO PROVIDE A DIRECTORY VALUE
directory=r"D:\Temp" #r"c:\temp"
#walk
print "processing" + directory
startTime=datetime.datetime.now()
#walk Through The Subdirectories
print "***Walk:\t" + directory
for src, dirs, files in os.walk(directory):
    #process Each Directory
    wsp=os.path.join(directory, src)
    print "***processing:"+src
    #get Files
    try:
        fls=os.listdir(src)
        for fl in fls:
            #check If Aux File
            if string.find(string.lower(fl),".aux") > -1:
                try:
                        os.remove(os.path.join(wsp,fl))
                except:
                    print "cannot Process " + os.path.join(wsp,fl)
    except:
        print "cannot Process " + wsp
#print Elapsed Time
print "Elapsed Time:" + str(datetime.datetime.now()-startTime)
#complete
print "complete"
SusanJones
remember to format with the tabs. all formatting is lost when I copied and pasted.
