Insert Object - Word .docx
1584
10-17-2012 11:02 AM
JimEverette
When I insert an object, a MS Word .docx (our disclaimer), into my .mxd layout, it does not stay when I close the .mxd then reopen it? How can I insert our disclaimer so that it will stay?
I tried to use other formats like .png, .bmp, .jpeg, but they do not allow me to adjust the object size. Sometimes I need to change the size of the text box depending on the frame size.
EthanSnyder
PDF files normally work the best.
MarkFawkes
We have our disclaimer as a normal (formatted) text box - this makes adjustments much easier (esp if you want to adjust the aspect ratio (height to width) by changing line breaks).
JimEverette
Thanks, that is a great idea. I'll do it that way.
