Import XML Workspace Document Fails
5417
04-15-2013 08:15 AM
TimDine
I am attempting to import an XML workspace Document into a 10.1 Geodatabase (Same issue with File and Enterprise geodatabases). I receive the error "Import xml data failed" "Fatal error parsing xml. Line = 1677445, char = 0. Reason: invalid character 0x8".
0x8 appears to be the utf-8 backspace character for some reason.
Im am exporting from 9.3.1 to import into 10.1.
I have tried exporting using both 10.1 and 9.3
A schema only import works without any errors.
Any idea what the error could be caused by?
Is there a good way to get more information about what is happening?
deleted-user-CGi_I1QLp6Ms
Hi Tim,
  I was wondering if you ever figured out a solution for this? I am currently trying to import a XML workspace document into a 10.2 SDE Geodatabase.  I am getting this error " Fata Error parsing xml. LIne - 16337, char =0 Reason: unexpected end of input."
I am exporting from 9.3.1 to 10.2.
Michelle
AsrujitSengupta
Does simple copy\paste or Export\Import work for the same data?
Roshan_MarkSingh_Matharu
Try exporting the xml under a different name from the original feature class and run the import again. This issue could be related to a possible metadata corruption during the first export.
