Import elevation data from a raster (GRID) into a multipatch -Is this possible? How?
2780
03-18-2013 06:35 AM
MaximSilin
Hi All,
I have a raster Grid file with elevation values. In ArcScene I can display a Multipatch shapefile (or feature class) floating on top of the raster surface (see the attached screenshot), based on the elevation values of the latter (i.e. raster). However, I'm wondering if there is a way to export those elevation values from the raster and then apply them to the multipatch to store permanently (i.e. I want my multipatch to have it's own elevation values corresponding to those of the respective surface). If anyone has done anything similar, please advised on the steps required.
Max
PrasantaBhattarai
After applying elevation to your multipatches from a raster surface, you can run Layer 3D to Feature Class tool which will then create another multipatch which should have the elevation information stored within the multipatches.
Regards,
Prasanta.
PrasantaBhattarai
Regards,
Prasanta.
MaximSilin
Hi Prasanta,
Thanks for the advise. However, when I ran the tool and added the resulting multipatch in my ArcScene, I've noticed two issues:
1) There were no elevation values associated with the new multipatch, unlike we were expecting - it was flat;
2) I couldn't even apply my raster surface elevation values to the newly created multipatch - it stays flat, and doesn't want to "float" on the surface no matter what I do.
Any thoughts on why this is happening? Any other workarounds to try for my original question?
Max
PrasantaBhattarai
Hi Max,
I have checked the workflow I suggested based on my understanding of the issue, and it seems to be working for me. See the screencapture video of what I was doing. Is this not what you were trying to do?
Prasanta.
MaximSilin
Nevermind my previous post - I've figured out what the problem was. Essentially, my multipatch was in the UTM projection based on the NAD27 datum, while the surface was based on the NAD83 datum. I've re-projected the original multipatch to NAD83 UTM Zone 18N, added it to the ArcScene, applied the base-heights from the surface, and re-ran the Layer 3D to Feature Class tool - the resulting output multipatch retained the raster surface elevation values within it.
Issue solved, thanks for your help!
Max
