Import & Export Table to Geodatabase from OLE Failing
723
01-27-2025 12:04 PM
Labels (2)
JD1016
I have tried both exporting a table from OLE to a GDB and importing a table to GDB from OLE and received the same error message 000732 and 000622.  I am using ArcGIS Pro 3.4.
I've attached a screenshot of the error message I receive from the Export Table attempt.  The Import looks much the same except with the error code 000622 not present.
Anyone have any suggestions on how I may remedy this problem?
Thank you.
JD
