Image Mosaicing issue
1501
06-15-2013 04:35 AM
by Anonymous User
Not applicable
Original User: sarz888826
i have two satellite images of Geo eye having same resolution & no Of bands but they capture on different time.when i mosaic in arc gis ...after mosaicking their color will be change ...is there any technique to mosaic these images without changing color schema.....i try in different software like Erdas,ENVI,Globalmapper but its showing the same problem.
Please check the snapshots attached below.
by Anonymous User
Not applicable
Original User: jbswain
Based on your last screenshot, it appears that perhaps you do not have the bands line up correctly.  I would normally suggest the color correcting, but at this point I would consider the metadata and be sure you have the bands line up correctly.
