How to symbolize unique values for single-band mosaiked rasters?
2560
12-13-2017 08:48 AM
MKF62
I have a mosaic dataset that contains 25 rasters. They all have the same symbology, but there is no option to symbolize by unique values in a mosaiked dataset. Unique values would be a problem for multiple band images, but not for a single band. Am I missing something? The only options I have in the symbology tab are Vector Field, Classified, Stretched, and Discrete Color.
This bug report says it was fixed in 10.1 NIM059496: Mosaic Datasets does not have an option for unique v..
It definitely wasn't though.
I'm working with a 1-band, 8-bit unsigned integer, "continuous" mosaiked dataset on 10.5. Is the fact that it's labeled "continuous" the problem?
DanPatterson_Retired
if they are indeed 1 band unsigned integer rasters, how did they get added as 'continuous' which to me implies a floating point raster not one that represents integer/image data.
JohnGaiot
I was wondering if this issue was ever resolved. I am getting the same problem. The original raster tiles can be displayed as unique integer values but when combined into a mosaic, the unique value option is no longer available even though the bit depth is the same as before (unsigned 8 bit). Is there a work around?
NickWeil
I am in the exact same situation. I know it has been a few years, but wondered if anyone found a solution? Working in Pro 3.4.2.
