how to import a shape file in the layer using a link?
1086
10-31-2012 02:17 AM
guidoSCHAEPMAN
Dear all,
In ArcMap I have got lines. These shape lines, with a field with the 'line number' (1234), are connected points. The unconnected points are in separate shape files on the harddisk. These files are named after the line number (e.g. 1234_points_shp).
Now, I have managed to create a hyperlink using the field calculator, however, then it opens the file in a different software. I would rather have ArcMap open the shape file in the layer in which I am working.
how can this be done? I saw that it is possible to edit the script, but I have no experience with this, so maybe you can help me.
Kind regards,
Guido
NOTE: I do not know whether this is the right topic to ask this question in. If so, my appologies, please send me in the right directoin.
guidoSCHAEPMAN
Dear All,
In the mean time I have had a reply from the ArcGis support (see below). I think it is a nice lead, however, I do not have python   scripting experience. Can you please send me in the right direction?
* Where and how do I specify in which directory the shape files with the points are?
* Where and how do I specify that the filename is the same as the attribute field name 'LINE_NR'?
* Can I use this script in the field calculator?
Kind regards,
Guido
Hello Guido,
Unfortunately I could not find a ready-to-use script to accomplish this. Writing code is beyond the scope of technical support.
I found a python script which you can use as an example to load the shapefiles programmatically through to the table of contents:
http://stackoverflow.com/questions/4017896/how-do-i-add-a-shapefile-in-arcgis-via-python-scripting
import arcpy
import arcpy.mapping
# get the map document
mxd = arcpy.mapping.MapDocument("CURRENT")
# get the data frame
df = arcpy.mapping.ListDataFrames(mxd,"*")[0]
# create a new layer
newlayer = arcpy.mapping.Layer(theShape)
# add the layer to the map at the bottom of the TOC in data frame 0
arcpy.mapping.AddLayer(df, newlayer,"BOTTOM")
# Refresh things
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
del mxd, df, newlayer
Maybe this can be a first step towards a solution.
