How to convert int type field to ObjectID type recognised by ArcSDE?
2153
04-04-2012 09:43 PM
AlexChen
Hello all,
I have a question for you to give me a hand please.
I have got an ordinary table with an OBJECTID column (type of int) in a SQL Server 2008 R2 instance. I need to store it in an ArcSDE geodatabase running on top of the SQL Server. The thing is how to make the OBJECTID field to the esri-compliant esriFieldTypeOID type so that feature operations through Feature Server can be applied down the track.
Any idea or tip would be really helpful! Thanks
Cheers, Alex
VinceAngelo
Esri Esteemed Contributor
If you have a table in a database where ArcSDE installed, and that table has a column
which maps to a 4-byte integer, and that column has the NOT NULL constraint, then
you can register it as USER-set registered rowid column via:
sdetable -o register -t table_name -c column_name -C USER -u owner ...
You can use ArcGIS to register the table with the geodatabase, but it's likely to
create a new column called OBJECTID and make it an SDE-set rowid.  ArcGIS will
not maintain USER-set rowid columns during editing operations, and in order to
make the table versioned, you'll need to register it as SDE-set ("-C SDE").
- V
VinceAngelo
- V
AlexChen
Thanks V for the reply.
It seems that I need to run that command line to make a column an esri-type ID.
