How to circle a polygon in a feature class?
1098
10-13-2012 10:22 AM
AbseenAnya
I have some small polygon features in a map that I want to highlight by placing circles around them. Since there are many little polygons, is there an automated way of placing circles around them? If so, is there then a way to have different colored circle around one of these polygons than all the others? Please let me know. Thank you!
Anya
T__WayneWhitley
Honored Contributor
Probably there is more than one way, maybe check out some of the techniques in representation or dimensioning...however; in a pinch, you could even use the Buffer tool and achieve some impressive results if you don't mind creating a 'spare' or temp fc.  If in your 'scratch' gdb, then no big deal.  Hint:  For those features clustered together you may want to 'dissolve' overlapping features - and the buffer tool will optionally do this too (or pick and choose, modifying the buffer output yourself to merge, move, etc., in your edit session).
DanLee
by Esri Regular Contributor
If you have an arcinfo/advanced licence, you can try one of the following ways:
Approach 1:
- Use Minimum Bounding Geometry tool (Data Management toolbox and Features toolset) with the CIRCLE option.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003q000000
The circles generated by this tool will vary in size depending on the polygon shapes.
Approach 2:
- Use Feature To Point tool (Data Management toolbox and Features toolset) with the INSIDE option to get a point inside each polygon.
- Run Buffer on the points with a desired distance to get circles of the same size.
Does that help?
