How to add a simple constraint in a file geodatabase
1411
07-23-2010 06:00 AM
OvidioRivero
I  want to add a constraint to make the value of a column "A" always bigger than the value in column "b".  This has to go on a file geodatabase.  On a personal GDB this is not hard but on a file gdb I have not firgured out how to do it.  My best guess is it can be done in XML? Has anybody done it?
Thank you all,
ben_abdallahmhd
"This has to go on a file geodatabase."
Please how do it?
I have a simular problem.
Thank you
StéphaneHenriod
Sorry for digging up this old post, but I currently ave the exact same question.
Is there an easy way to implement simple constraints in a File Geodatabase (foreign key constraints, for example)?
I couldn't find any documentation on that...
Thanks a lot in advance!
Stéphane
