How to access a MS SQL 2008 multiversion view from a remote database
1181
08-30-2010 02:15 AM
DionLiddell
I can create a multiversion view and then use 'set_current_version' to change to the version that I require.  And this is all good if I am accessing ArcSDE programmatically or through the interface presented to me by SQL 2008 Manager.  But how can I set up a view that can be accessed via a remote connection such as through a 'linked table' in Microsoft Access?   I need to be able to serve the view in a standard (think ODBC connection) way to the client that will be using the view.
Because the set_current_version stored procedure must be executed before the correct version can be seen in the multiversion view, it appears to be difficult to present the view as an easy-to-use ODBC connection that can be consumed by a remote client.   Any help on how to get around this problem would be very much appreciated.
Regards,
Dion Liddell.
DionLiddell
In answer to my own question, I've created the following 'hack':
1. I created my own copy of the 'set_current_version' stored procedure.  My 'force_set_current_version' stored procedure removes the owner and protected checks that exist in the original.
2. Grant the Public role the Execute permission on the 'force_set_current_version' stored procedure.
3. The 'force_set_current_version' is then put into a logon trigger so that it is called whenever someone connects to the ArcSDE database.   I specify the version to use in the logon trigger.
4. Grant my users the Select permission on the multiversion views.
