When importing a .dwg file in arcmap, is the OBJECTID field generated based on a propertie from the CAD file, or is is just giving an ID based on which feature is processed first? I have some labels to associate with line objects and there are too many to just use a near tool, but it seems that the OBJECTID of both labels and lines match each other. Could these values created from, for example, the order of drawing in autocad?
I assume they are as they were created. there is nothing is reserved work list to indicate otherwise
Reserved CAD fields for AutoCAD DWG/DXF formats—Help | ArcGIS for Desktop
After taking a data sample for a test, it seems to indicate that the labels can be joined to the lines using OBJECTID.
A good place to put this thread would be in the CAD/GIS Data Integration group ![]()
