How do I display code values domain in ArcMap ?
2847
07-14-2016 09:55 AM
DEAF_PROBERT_68
Honored Contributor
Here I have a Feature Dataset that was done in SDE.  I have a point sde feature class and one of the  field name that  has a domain already set up.
Now, when I bring that sde layer to my ArcMap and use the symbology to build the values for each feature. I do notice that the "all other values" incorrect and I realized that I need to symbology the Coded value domain that can show the descriptions for each values that shows on the attribute table ?
How do I do that for ArcMap 10.3.1.
RexRobichaux2
Hi Robert,
Just to clarify, are you seeing the descriptions for the domain rather than the coded values? If this sounds like your problem  there are a couple of ways to change settings in the documents to display the domains rather than descriptions: How To: Display coded value domains and subtype codes instead of descriptions . I hope this is helpful for you-
-Rex
