How can I assign current date to a Date Field as Default Value in ArcGIS 9.3.1.
5495
09-01-2015 05:23 AM
PerMølsted_Jørgensen
In ArcGIS 9.3.1 I want to assign the current Date as a Default Value to a Datefield. I thought I could use Now() as the Default Value, but it doesn't Work.
I know I have done it before, but I have forgotten how
Hello
I have tried with getdate() in stead, but that didn't Work neither.
But I found out of what I had done earlier.. I did not use ArcCatalog or ArcToolbox to set the Default Date Value.
I used a personel geodatabase (Access), and in Access I could set the Default Value on the Date-field with Now().
And that Works. Now when I open the Feature Class for editing in ArcMap the Default Data (Current Date) is automatically filled in.
JayantaPoddar
Try using getdate() function instead of Now()
Think Location
Hello
