Hi all, I am looking for a way to create an automatic tool for importing excel tabular data(which are updated over time) in Arcmap using Model Builder tool. Is it possible to do it?
3575
11-30-2015 09:10 AM
DANIELAMATTINA
Hi all, I am looking for a way to create an automatic command for importing excel spreadsheets (which are updated over time) in Arcmap using Model Builder tool. Is it possible to do it? In that way I can run the model whenever new data are stored in tables excel. Many thanks, Daniela
DarrenWiens2
Have you tried (and do you have access to) the Excel to Table tool?
DANIELAMATTINA
Thanks for answer, No I haven't tried, as I would create an automatic model with model builder. I am using ArcGis 9.3
DarrenWiens2
I'm not sure what your options are in 9.3, but I don't believe Excel to Table existed then. Have you tried the Copy Rows tool?
I don't understand what you mean by you haven't tried the tool as you want to create an automatic model with model builder. I assume you will be using geoprocessing tools in your model?
DANIELAMATTINA
yes I am using geoprocessing tool and through Model builder I would create
an automtic model for importing excel table which are updated every month.
Do you mean to cerate a model using the tool Copy rows in Model Builder? I
can try it and check the result.
