GeoServer WFS in ArcMap via Data Interoperability Extension - ogc:filter errors
4666
03-09-2012 04:22 PM
TomCohen
I have posted a very similar message in the GeoServer forums as this is as much a GeoServer problem as ArcGIS. I'm hoping someone here has experience connecting ArcMap to a GeoServer WFS.
I am connecting ArcGIS (v10, SP3) to a GeoServer (2.1.3) WFS through its Data Interoperability Extension. The extension is unlicensed, but a license isn't required for basic WFS data retrieval.
The DIE has two ways of retrieving data - simple GML features and WFS. Simple GML will always cache the data (24 hours?) but WFS gives the option of always getting live data from GeoServer - this is what I need.
I set up the connection and added a GeoServer WFS resource to the ArcMap table of contents, but when I open the attribute table every single attribute is listed as null. I did some digging and found that ArcMap is making a GetFeature request for every visible row in the attribute table and is using the Filter structure in request parameters. Filters look like this:
<ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>local:ID</ogc:PropertyName><ogc:Literal>149</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
GeoServer errors with a parsing exception - it doesn't understand the ogc: prefix because "The prefix "ogc" for element "ogc:Filter" is not bound". If I send the same request but without the ogc: prefix the response is as expected.
So to see live GeoServer WFS data in ArcMap I need to either
1) configure ArcMap to not use the ogc: prefix on Filter, or
2) configure GeoServer to not complain when the ogc: prefix is provided.
Given that ArcMap and GeoServer are both quite common I was hoping this issue had come up before, but so far I've found nothing.
Any suggestions are very welcome.
TomCohen
Having thought on this for a while I think the problem could also be solved by ArcMap making POST instead of GET requests - then the POST request body would contain an XML document and (hopefully) a namespace declaration for 'ogc:'. I think the problem is that the GET parameters include an XML fragment which assumes the server understands the ogc: prefix, but no namespace declaration is passed.
I know that FME allows me to specify that its WFS reader should use POST, but I don't see the same option in the ArcMap-integrated FME components provided in the Data Interoperability Extension.
BruceHarold
Esri Frequent Contributor
Hi Tom
The POST option will be in the 10.1 release of Data Interoperability.
Regards
TomCohen
Hi Tom
Regards
Thanks Bruce, I read that 10.1 should be out in May. If this release and its POST capabilities solve my problem I will be very happy.
I am in the fortunate and unusual position of being able to wait a few months to get this resolved. An alternative approach I am considering but would like to avoid is writing a proxy to GeoServer (mainly for more fine-grained security than WFS supports) which could also strip the ogc: prefix out of any filters passed, or construct POST requests from GET parameters.
