GEoreferencing disabled
1098
02-13-2013 03:55 AM
JamesHarrington
Hello
I have 3 georeferenced TIFs on a map. I used georeferencing to adjust their locations to match the airphoto basemap, then checked 'update georeferncing' for each. Apparently, once you do this, you can NEVER go back and make additional adjustments? I even tried deleting the .aux.xml and ovr files, and add the images again - to start all over again - when I do this, the georeferencing toolbar is disabled. I ever moved/renamed the images, changed the coordinate system, etc. The data frame is not rotated. Please help!
JohnSobetzer
Honored Contributor
If you don't mind starting all over again, use Windows Explorer to copy and paste your images to a new folder, or use it to rename the tifs in the current folder.
