Geometry in GML does not show valid type in ArcMap
1601
08-31-2012 03:49 AM
Reza_MahmudunNaym
Hi
I was trying to transform GML data to File Geodatabase. The GML contains point geometry. But when I put the GML in ArcMap layer it shows type "Multipoint" and also when transforming it into Geodatabase, same result in there.
Then I created a simple point feature class and convert it back to GML using Quick Export(Data Interop Ext), there the GML also shows the type "Multipoint". Can someone help me where I did wrong to get it as point feature in GDB ?
Naym
BruceHarold
Esri Frequent Contributor
Hello Naym
GML (and WFS) "points" are handled as multipoint.  Please use the geoprocessing tool "Multipart to Singlepart" to convert GML multipoint to Point data.
Regards
