Geodatabase Design
8220
18
07-08-2010 08:31 PM
stephanieduce
I have a lot of data including roads, drainage, contours, land use, habitat, shorelines, marine protected areas (.shp) as well as DEMs etc.... for a group of islands. I would like to organise this data into one, or more than one, geodatabase(s). I have not worked with geodatabases before (though have done quite a lot of work with GIS) and am not sure how best to approach this.
- Would it be best to make my own data model or to add my data to an original data model such as ArcMarine etc...
- Should I create separate geodatabases to house the terrestrial data and the marine data? If I do will it be fine to work with them both simultaneously in ArcMap? They are both the same coord system.
- Would it be appropriate to divide each island's data (i.e. roads, infrastructure, buildings etc..) into a separate feature dataset within a geodatabase?
Any help will be much appreciated.
Thanks in advance,
Steph
LukeGilner
I am also in the beginning stages of database design.  I was originally planning on going with the file geodatabase, but I would like the ability to use Excel and Access for editing, querying, reports, forms, etc. so decided to go with the personal geodatabase.  Is this an acceptable approach?
DerekLaw
Esri Esteemed Contributor
Hi there,
... but I would like the ability to use Excel and Access for editing, querying, reports, forms, etc. so decided to go with the personal geodatabase. Is this an acceptable approach?
You should use the type of geodatabase that best meets the needs of your business workflow, so using a MS Access personal geodatabase is fine. However, please be advised that directly editing a personal geodatabase with MS Access is not recommended.
Understanding how to use Microsoft Access files in ArcGIS
Hope this helps,
JoshuaDamron
I appreciate finding an entry level discussion of geodatabases.  I have a ESRI book "Designing Geodatabases" from 2004 which I am reading and I am looking into purchasing the book Derek suggested.
While our City has been using ArcGIS for the past 10 years, due to constraints with the 3rd party web interface we've been using we have not ventured into geodatabases.  We are now working to take our GIS to the next level �?? we recently began using ESRI�??s Small Goverment Enterprise package & will be moving to ArcSDE & SQL this coming summer.
I apologize in advance for the long list of questions below but I�??ve been chewing on a bunch of questions and it would be great if someone could help me gain some clarity:
1) We are in the conceptual stage of building file geodatabases.  With moving to SDE & SQL on the horizon, what considerations should I be taking in constructing my geodatabases?  Do I run the risk of having to redesign my entire geodatabase from scratch once we move to SQL?
2) I am trying to wrap my mind around the various constraints in geodatabase structure design.
If I understand Topology Rules correctly, topology relationships can only be created/maintained between feature classes within the same dataset.  Originally our plan was to maintain our current folder structure by creating Geodatabases for different department uses (Public Works, Planning, Fire, general shared planimetrics, Parks, etc.)  Learning about how relationships work via datasets we considered a larger geodatabase with each department in their own dataset.  However from what I'm reading this is a bad idea though I don't know why.... I am assuming I am not grasping some of the concepts which make up a dataset.
Reviewing ESRI's design models <http://resources.arcgis.com/content/water-wastewater-and-stormwater-data-models%20> I am not clear on why each utility is broken out into its own dataset, I suppose there are limits on how many topology rules/geometric networks a dataset can handle? (Perhaps I'm simply stuck on editing in our current file structure where I edit the Public Works folder and I am able to edit all of the utility data vs each utility broken out into its own data set to be edited individually).
A similar issue is that we would like for changes to the parcel layer (in the general shared dataset) to directly relate to the zoning features (planning dataset) and water zones features (public works dataset) etc.  Can relationships and topology be built between datasets?
Can a dataset have both topology & geometric networks?
3) Are there limits to how many feature classes can be in a given dataset?
4) We are designing a global ID system for all of our utility assets and dynamic values are a new territory for us, could someone point me in the right direction for creating GUID dynamic values?  If all of the features are within the same feature dataset our GUID�??s can be designed to be unique between each of the different feature classes right?  When I right click a feature dataset in ArcCatalog I have the option of "Add Global IDs..." after doing this I check out the properties of the features within that dataset and under the Fields tab it shows a new field "GlobalID", however when I add these features to a map I don't see this field, Am I missing something?
5) The Geodatabase Diagrammer links posted above are for past versions of ArcGIS, is this ability still available for Arc 10?  Now that I've moved to Arc 10 I'm having trouble finding Scripts for the new version, is there a guide to what 9.3 scripts from the ESRI website carry over into Arc 10 or do none of them work?
Again I apologize for dumping all of these questions but the Help Docs & Forums are anything but exhaustive.
Any assistance is appreciated.
DerekLaw
Hi Joshua,
A1) Please listen to the Esri Instructional podcast titled: "Migrating from Single-user Geodatabases to Multiuser Geodatabases". A transcript is also available.
Esri Instructional podcasts
(look under the Geodatabase filter)
A2) Geodatabase schema design is transferable between different types of geodatabases. So you could define your GDB schema in a File geodatabase, then migrate it to an ArcSDE geodatabase. But there many be some additional considerations when migrating to an ArcSDE geodatabase - please refer to the podcast.
A3) I believe relationship classes can exist across feature datasets. Topologies only exist within the same feature dataset.
A4) Yes, a geometric network and a topology can both exist within the same feature dataset. However, feature classes in the feature dataset can only participate in either the geometric network or the topology. They cannot participate in both data structures.
A5) I'm not aware of any known limits.
A6) FYI, the Geodatabase Diagrammer has always been an unsupported Developer sample for ArcGIS. I don't believe the developer who wrote it has migrated it for ArcGIS 10.
Hope this helps,
CFrate
We're about to move to ArcGIS 10, and I've been looking into whether there are new options for geodatabase design in the new version.  However, most of what I'm reading online seems to suggest that, although designing with UML is still supported, ESRI now recommends doing everything within ArcCatalog.
But I see nothing so far suggesting that ESRI has improved this experience.  Is there a way in Catalog now to create the database as a diagram (a la Visio)?  Or does is it still the tedious process that it has been in the past, with no way to review the entire database on screen as I make changes?
Thanks.
DerekLaw
Hi Carlo,
No, this functionality is not available in ArcCatalog. I suggest you vote for this functionality on Ideas.arcgis.com:
Idea: Add a utility or tool to create, edit and analyze the geodatabase schema
Hope this helps,
CFrate
Hi Carlo,
Hope this helps,
Will do.  Thanks.
So, although ESRI's official suggestion is to move away from working in UML, there is no better alternative available?
danan
One possibility is Enterprise Architect's new ArcGIS UML profile:
I blogged about it here:
http://spatialdba.com
http://spatialdba.com/?p=50
If you follow the links through to Sparx Systems' web site, you'll find a video demo:
http://www.sparxsystems.com/resources/demos/arcgis/arcgis-ea-intro.htm
ThomasStanley-Jones
If anyone finds this thread, just wanted to let them know that the Geodatabase Diagrammer for ArcGIS 10 can be found here:
http://resources.arcgis.com/gallery/file/arcobjects-net-api/details?entryID=F12ADF8F-1422-2418-34B2-...
or a slightly different implementation here (haven't tried this one):
http://www.arcgis.com/home/item.html?id=a378b48be11b45b5bb25254643304cb7
