Geocoding Project
4262
7
06-24-2013 09:31 AM
CameronBentley
I am in charge of a GIS project for an internship I am doing this summer. I have taken a few GIS classes but by no means am I an expert, and no one in the office knows much about GIS. I have to map the locations of their projects, most of which have been in Colorado. I have the specific addresses and zip codes for most of the projects as well as the counties. What would be the best way to go about this? I have added the Colorado state boundary and county boundaries (I also have access to the zip code boundaries for Colorado). I know I have to geocode the addresses to a layer of street data for Colorado (which I have never done before), but have been unable to find any layers that are suitable for this. Any tips on where to locate a layer such as this or on geocoding would be much appreciated.
Thanks!
JoeBorgione
Hello again!
I am having trouble creating the address locator from the street data I have and my data table. I obtained the street data from a US Major Roads layer found on ArcGIS online, and selected and exported only the roads in Colorado. I have read many tutorials and
watched some videos online about creating an address locator and I am afraid the street layer does not have all of the necessary
data. I have attached a copy of the project data I am using as well as a snapshot of the street attribute table (which consists of 13015 attributes). Does the street layer need more information such as distance from/to the right/left/etc? I appreciate all the help!
Cameron-  let's get some nomenclature taken care of first: the street data you show has 13015 RECORDS but only a handful of attributes: records are rows, attributes are columns.  This particular street data does not have the proper attributes to support geocoding.
I've been surfing around looking for a good source of street centerline data for Colorado this morning.  So far the best information is the tiger-line data from the US Census; check out this pdf that has download instructions and use instructions.  Once the sun comes up, I'll make a call or two to some of my Colorado contacts and see what they can suggest as well.
Your address data looks good, but needs a few minor tweaks: get rid of any special characters, suite numbers and then standardize your street types.  For example:
603 Main STREET, Suite 2 should be cleaned up to
603 MAIN ST
Some of your address have STREET others have ST.  Some have AVENUE others have AVE.  No sense reinventing the wheel here; the USPS has a list of standards you can follow.Click on the abbreviations tab. (I use these in two major 9-1-1 call centers in Utah and geocode/dispatch hundreds of thousands of calls per year: when seconds count, help is only minutes away...)
This should keep you busy; I'm grabbing another cup of coffee and watch the sunrise. (BTW, don't be shy about following the instructions given in my signature block below.)
That should just about do it....
JoeBorgione
This is like deja vu all over again;  I swear I replied to this same post last week or so and I remember someone from ESRI responding as well.
My response was to get some local street data from Colorado or the Counties; the other response was to use the packaged data that comes with ArcGIS.
Either way, take a look at the online help on how to create a locator, and you'll be good to go.
CameronBentley
Thanks for the response, and, yes, I did post something similarly last week. I was just having difficulty finding a layer with sufficient street data. However, I've resorted to doing it by county, but I am having difficulty joining the table to the layer of Colorado counties. I need to create a many-to-one relationship between the table and counties layer because some counties have more than one project that was completed in that county. When I join them, it takes the first project from each county and that's it, so out of the 63 projects I want to map, only 24 show up. Is there a better way to do this? I appreciate all the help (this week and last).
JoeBorgione
You can create a locator based on the county name: look here to learn about a general, sing field type of locator. I believe that this method will 'stack' your project points in a pile at the centroid of the county polygon centroid.  Take a look at using the dot density method to represent them on a map.
CameronBentley
Hello again!
JoeBorgione
Hello again!
603 MAIN ST
CameronBentley
I appreciate all of the help, Joe. I have fixed my excel sheet so it is compatible. I am still working on finding a street layer via the
Tiger shapefiles you suggested. Hopefully i come across something that works. Again, thanks for the help.
JoeBorgione
Just hit the mother lode for Denver.  I couldn't get to this site earlier today, but it's got just what I had hoped to find and then some:
http://data.denvergov.org/dataset/city-and-county-of-denver-street-centerline
And this place has many other Colorado jurisdictions:
http://data.opencolorado.org/
