Geocoding Issues
3741
03-05-2011 02:35 PM
DanielBirmingham
Hello;
I am using ArcGIS 9.3 and am having trouble geo-coding. I am trying to geo-code entire states at one time. I am using 2010 TIGER files as my reference data, which are projected to NAD83. My addresses are in a Excel .xlsx file that I added to ArcMap. With the address locator created from the reference data, I try to geocode the addresses for that state.
I am immediately getting an error that says "Create Feature Class: There was an error trying to process this table."
This error is very vague and frustrating, please help!
JoeBorgione
Take a look at the field names in the spreadsheet.  If there are any special characters or spaces in the field names it'll choke.
That should just about do it....
RebeccaSeel
Did you figure out the problem, and/or the solution?  I am having the same issue and believe there is a better way than individually reviewing 100,000+ addresses.  If you would, plaease share how you are working around this problem.
Good luck!
Hello;
JoeBorgione
I'm not suggesting to look at each record, just the field names of the address table.  However, you may also want to look for <null> values within the actual records. I don't like using spreadsheets for address tables; I'd rather upload them into some flavour of geodatabase.  The select tool is good for listing all the values in any field including <null>; you let the machine do the work, right?!
DanielBirmingham
Hello, I solved the issue. Joe was right. It was the field name headings that were an issue. Knowing this previously, I took all special characters and spaces out of the names and replaced them with underscores. This was still crashing the geo-coder. To fix this, I removed all the fields except for address, city, zip, and state. The geo-coder ran after this fix. I will add these fields back in after I am finished geo-coding. Good luck.
