geocoding in python
1110
02-07-2012 04:12 AM
NathanBaylot1
[INDENT]Is there a way to change the geocoding options in python? I geocoded the file and the standard score is 85, well all the 84.19 scores work perfectly. I have not figured out how to set the score in python.[/INDENT]
TimDine
Was this ever resolved?  I've been able to geocode with Python, but I can't get it to accept lower match scores.  I've tried lowering the score in the locator,but no luck on making the matches happen lower.  I have been able to make this work interactively in ArcMap.
BruceHarold
Esri Frequent Contributor
Hi
There are no ArcPy methods to access the run-time properties of a locator, but if the locator is file-system based then you could write code that changed properties in the .loc file - which is ASCII.
Regards
