Geocoding Developer's Kit for ArcGIS 10.0?
11761
27
10-18-2010 01:36 PM
JonHall
Is there a "Geocoding Rule base Developer Guide", and GDK, for ArcGIS 10.0?
If so, how where may I obtain a copy?
Jon
I looked back a couple months in this forum, and Bruce H. had responded on 8/26/2010 to a similar Q:
"...10.x locators use the all-new geocoding engine in ArcGIS 10. These are customizable via editing the .lot.xml file(s) in the Locators directory. Documentation for this is still under construction, but you should be able to see similarities with the CLS file elements."
Any update on the status of that documentation?
Jon
BruceHarold
Esri Frequent Contributor
Yes, you can do that; we don't test it much but we think it 'should work' for Desktop workflows.
I'm not sure what the official support position will be, probably unsupported.
GabiVoicu
That will be fine - it won't be the first time to try a workflow that is not officially supported ...
I'm sure we have all done it ...
Thank you again
GabiVoicu
Can I install ArcGIS Pro 10.4 on my computer while all my ArcGIS is 10.3?
BruceHarold
Yes certainly, provided the computer meets system requirements.
You mean Pro 1.4 though.
GabiVoicu
I meant Pro 1.4 yes, you're right !
We may need to update our ArcGIS License Manager at least, to 10.4 if nothing else ...and by doing that still everything should be backwards compatible and work just fine ....correct?
Thank you
BruceHarold
Well if you have any 3rd party extensions you may need to update those but in theory everything else should work.
Regards
AllenMartin
May we have an update to the expected availability of the GDK for v10?
Allen
deleted-user-F4cUDEZyawYe
We too need a Geocoding Rule Base Developer Guide for v. 10.
