Hey Everyone!
We've added the Generate Schema Report tool to ArcGIS Pro 3.2 and want to hear your feedback about it. I've posted a blog post to add context to the project with a brief history and also a look at where we'd like to take it in the future.
We know X-Ray was a much-used tool and hope this can help with some of the same workflows. Moving forward we'll be addressing a key workflow many of you have asked for: The ability to make schema changes in the Excel output and then reimport to create a new geodatabase with those updates. We're hoping to get this into Pro 3.3.
The Schema Report is available now but it's also a work in progress and we'd very much like to hear from you:
Here are some links to related content:
I hope you find the tool helpful. Give it a try and let us know what you think.
Cheers!
Jonathan
This tool needs the ability to not just create a schema report but also allow editing of the schema and upload those changes back to the database. This was a tremendous time saver.
Generating a report of one dataset or a group of datasets (along with domains) is a very useful tool. However, the gdb x-ray tools real power is being able to alter the schema domain and reload it to a file or enterprise gdb. The only workaround I've found is use use FME from Safe Software.
Yep, agreed. This was the key workflow. As mentioned in the blog, updating the schema in Excel and reimporting to create a gdb with the changes is the next phase of this project. I'll add this info to this post here so it's clear that's where we're going with it.
Thank you to the Esri team for this much needed integration in ArcGIS Pro itself. A couple of suggestions from a quick look:
I'd love to generate a schema report in the form of an Entity Relationship Diagram - ERD. If I recall right, Sparx Enterprise Architect can do it after importing a geodatabase XML Workspace Document. It would be proper to right-click the GDB and say, "make an ERD" as PDF or HTML format. Maybe there's already a tool for doing just that using the JSON or XLSX formats?
Like time-back-way-back with, what was it - ArcCatalog and Visio? https://desktop.arcgis.com/en/arcmap/latest/manage-data/geodatabases/documenting-your-geodatabase-de...
Would it be possible to add one more level to the "Domain Usage" tab, whereby clicking on the domain name would give a report of the contents of the Domain?
One thing I would love in the tool itself it the ability to over write the file that is created. This would help with automation, I did create a python file that kind of does that but it would be better if baked into the program.
# Name: GenerateSchemaReport_Example.py
# Description: GenerateSchemaReport of a file geodatabase
# Import the system modules
import arcpy
import os
# Set local variables
gdbWorkspace = "gdbWorkspace"
outputFolder = r"OutputFolderLocation"
outputFile = "SchemaReport.html"
outputPath = os.path.join(outputFolder, outputFile)
# Check if the output file exists and delete it if it does
if os.path.exists(outputPath):
os.remove(outputPath)
# Generate schema report
arcpy.management.GenerateSchemaReport(gdbWorkspace, outputFolder, outputFile, ["HTML"])
Thanks for this--great tool!
One thing I would like to see is whether or not a feature class is versioned and if so, what type of versioning.
Zak--
I have three requests for changes to the output of the Schema Report tool, so I'll post them in three posts to make it clear. But firstly, I just want to say THANK YOU! This is great step forward. And it is good to hear that further improvements are on the way.
REQUEST ONE:
It would be great if the HTML report included a table of contents with links to each section (I think the XRay version used to have this?). In particular, I want to be able to click a link to jump straight to the Domains section, without having to scroll through, or do a search for it.
