generate a new column on a table
1355
11-29-2016 07:36 AM
johnwoollett1
I have a data table and want to perform an sql query to build a new column on the data containing data from several data columns, how can this be done?
eg  IF(FIND('-',Location_Code)=4, LEFT(Location_Code, 12), LEFT(Location_Code, 13))
thanks  john woollett
Tags (1)
AdrianWelsh
MVP Honored Contributor
John,
What format is your data table in? What software are you using for running this SQL query?
In any case, take a look at the info here. This might help:
Building a query expression—Help | ArcGIS for Desktop
johnwoollett1
Hi
Its in an oracle database, I want to reproduce a Functional Attribute from an Intergraph geoworkspace.
I need to use FIND,LEFT,RIGHT functions to compile the result
thanks
AdrianWelsh
John,
You may get better luck placing this thread in Enterprise GIS‌ or ArcGIS for Server‌. Having oracle tags in it would help as well.
