gdbt not functioning
812
07-22-2010 07:24 AM
SeanRedar
I have the gdbt installed (v9.3.1 sp2), however it doesn't seem to be functioning.  I have tried to view both enterprise (oracle 11g) and personal sde instances to no avail.  Also attempted to install manually, still no luck.
DerekLaw
Esri Esteemed Contributor
Hi Sean,
  1. What kind of error(s) are you getting?
  2. Can you provide some screen captures?
  3. What release versions are the geodatabases?
  4. Was it working previously and then it just stopped? If so, did something happen in-between this occurrence?
FYI: Technically the Geodatabase Toolset (GDBT) is an unsupported developer sample extension.
