Fully qualified table name in Postgres
6228
06-11-2010 01:05 AM
StefanOffermann
Can anyone give me a quick hint on how table names are fully qualified using a PostgreSQL database? I am not sure if it is
<dbname>.<owner>.<tablename>
or
<schema>.<owner>.<tablename>
I want to use it in a configurable python script, eg
CopyFeatures "C:\local\Shape_1_1.shp" "Database Connections\pg.sde\<?>.<?>.Test_1_1" # 0 0 0
I am using SDE 9.3.1
Best regards, Stefan
TITTIT
Maybe to late, but:
The schema is:
<dbname>.<schema>.<tablename>
whereby <schema> is the same as <user>
(there hasn't to be a arcsde user without a same named schema)
greetz
StefanOffermann
Thanks for your answer, I figured it out already (I had some time since november 2010 *g*)
