Finding Duplicate lines or lines that intersect.
11213
11
08-06-2012 07:49 AM
JayKappy
I have a single Feature Class of Pipes....I noticed that somehow along the way Duplicates were created.
They are basically exact duplicates right on top of one another.
Is there a tool to run to find the lines that intersect or duplicate in a single Feature Class?
THanks
NobbirAhmed
Esri Alum
Hi Jason,
Try this code. Set the path of your input data to in_fc. I haven't done anything (other than printing) with the duplicate features - you'll need to use either an insertcursor (with a new empty feature class) or updatecursor (to work with current feature class) to carry over the unique features.
import arcpy
in_fc = r"C:\mytools\findidentical\geom_equals.gdb\trailsfew"
dsc = arcpy.Describe(in_fc)
sr = dsc.spatialReference
oid_field_name = dsc.oidFieldName
# get a cursor on the input features
rows1 = arcpy.SearchCursor(in_fc)
# exclude features already compared once
exclude = []
# iterate through the first coursor
for row1 in rows1:
    oid1 = row1.getValue(oid_field_name)
    shp1 = row1.shape
    # get a second cursor on the same input features
    rows2 = arcpy.SearchCursor(in_fc)
    # add the feature to be compared to exclude list
    exclude.append(oid1)
    # create a set to hold duplicate features
    group = set()
    # iterate through the second cursor
    for row2 in rows2:
        oid2 = row2.getValue(oid_field_name)
        shp2 = row2.shape
        # ignore features already compared
        if oid2 in exclude:
            continue
        # test equality
        if shp1.equals(shp2):
            # add both feature ids to the set of identical features
            group.add(oid1)
            group.add(oid2)
            # add the feature just compared to the exclude list
            exclude.append(oid2)
    if group:  # if the group is not empty
        print group
Note: I have used two separate cursors on the same feature class. This is due to some issues at 10.0 - at 10.1 one cursor is enough.
Let me know if you find any issue or if you need help with creating an output.
Thanks, Nobbir
JasonKleps
Hi Jason,
Thanks, Nobbir
Thanks Nobbir - This is a great Christmas present!
- Jason.
