Field Calculator and Base Tables
828
12-02-2010 01:05 PM
LauraCarr
Hi All,
Does anyone know when using the Field Calculator in ArcMap, does that make the modifications to the A & D tables in ArcSDE or to the Base tables?
I ask because we used the Field Calculator, hit Save Edits and then the Conflicts window appeared.  Generally you only get this after you have performed a reconcile - which had NOT been done.
We are using ArcMap version 9.3.1 and ArcSDE 9.3.1 in SQL Server 2008.
Laura
VinceAngelo
Esri Esteemed Contributor
Edits to a versioned table, even one set to "move edits to base", go through the A/D tables.
I once had a customer who was tweaking network weighting values on a large (200k rows)
table and was complaining about poor performance -- If turns out they had 30 million rows
in both the An and Dn tables.  I recommended they put modeling constants in a joined table,
one edited with an ODBC connection.
- V
