Feature class Attrbute field discription table
2912
10-17-2014 11:10 AM
StevenJin
Is there a table that defines all the fields property with description?
TimWitt2
I think your are talking about metadata? ArcGIS Help 10.1
StevenJin
Tim,
Thank you for your answer, and I want to elaborate my question a little bit more.
actually i am looking for a summarized description table of a data model or schema.
currently I am in the middle of adding more fields in 'emergency response' feature class, and i am using to local government data schema. Just in case later I need present these fields to my clients or answering questions about the fields, I want to know if there are any summarized description for each field.
I remember saw a table before that shows all facility feature classes. and it further shows all fields that needed in each feature class, also with explanation.
wish I can find that table again, but I can not remember where was it from.
Do you have any information about it?
thanks
