Extract self-intersecting portions of a polygon.
2161
10-03-2013 10:26 AM
RobChouinard
I have a shapefile to has polygons that depict the areas our helicopter has treated. The issue at hand is where the polygon intersects itself it shows a hole/gap where the helicopter did actually treat, twice at that. I can't seem to find a way to extract the areas where the polygon self-intersects. My end goal is to create c# code to accomplish this in ArcObjects prior to merging in a database.
Example: Left is the self-intersecting polygon that has not been repaired. Right is the portions I want to extract.
[ATTACH=CONFIG]28021[/ATTACH]
TimWitt
Rob,
check out the discussion found here. Sounds like they had the same question.
Hope this helps!
Tim
RobChouinard
This works great for overlapped polygons in the same feature class. I need to extract self-intersecting polygons/portions from a single polygon. I have tried to run Intersect on a single self-intersect polygon feature class and it generates an empty output.
