Exporting InfoNet to SDE
1011
04-20-2010 05:34 AM
KennethBusby
Has anyone exported directly to and SDE from InfoNet? If so what permissions did you have to open for that to happen? Thanks!
Ken Busby
VinceAngelo
Esri Esteemed Contributor
Google shows half a dozen different InfoNets.  Which one are you using?  What formats
does it support for export?  ArcSDE dosn't support a great many formats directly, but supports
dozens of standards through ArcGIS.  Getting data into a database configured with ArcSDE is
generally a simple exercise.
Necessary privileges for ArcSDE use are determined by relational database -- which one are
you planning to use?
- V
KennethBusby
It was origionally a Wallingford Software product but has recently been bought by MWH Soft. It supports geodatabase export and SHP files. We attmepted the export but are trying to track down the required permissions for our SQL server to allow it. We had success with full permissions but the IT dept. wants to know the required permissions so we do not need to allow full permissions to be used which is not a possibility. We are trying to set up a direct link and use the auto export software to do a routine update. I was just thinking if anyone else was using it they may have allready set it up and would have some ensight on how we could do the same.
-Ken
