Export rasters from an unmanaged raster catalog
2290
11-18-2010 07:38 AM
HugoMercier
Hi everyone,
I use unmanaged raster catalogs (MA catalogs using rpf format). I would like to create raster packages from a selection of a raster catalog. I've already tried various tools but they all copy the links and not the rasters.
Anyone has a solution?
My next step is to create a script but I want to be sure I've tried everything before I do that.
Thank you all for your time.
Hugo
EricRice
Esri Alum
Hugo,
The Raster Catalog To Raster Dataset tool has a parameter called, "Expression", which allows you to select specific records in the catalog to mosaic together.
Since you have RPF catalogs I assume you have the Military Analyst extension installed.  There is a mosaic command on the MA toolbar to mosaic subsets of the MA catalog.
If you are using ArcGIS 10, the Mosaic Dataset might be your best option.  The RPF tiles will be treated as a mosaic, and unlike a raster catalog, the mosaic dataset can be input into geoprocessing tools.  In this case it seems all you would need to do is run the Clip tool on the input mosaic dataset.
Regards,
Eric
