Existing geodatabase - need help please!
925
04-18-2011 10:23 AM
SarahSullivan
I have an existing geodatabase (MS Access 2007 - mdb) with some "OLE Objects" in it.  I've never used OLE Objects before, so I'm hoping someone can provide me with a little info...
A)  Is there anywhere that would tell me if these OLE Objects are already connected to an ArcMap project somewhere?
B)  Can I view/edit the OLE Objects in Access?
C)  Can I view/edit the OLE Objects in ArcMap?  (If so, how?  I've tried using these intructions, but I can't seem to display more than points, and I should have line segments: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//005s00000023000000.htm)
(Sorry if I'm completely on the wrong path... as I said, I've never used OLE Objects before.)  Thanks!
