ERROR: while creating feature class in Oracle DB
1238
04-02-2013 02:35 AM
AmitGupta
Dear All,
I'm facing a bit problem while creating a feature class, details are given below connection method is direct mode using ArcGIS 10.1 and oracle 11GR2.
Error details:
Failed to create feature class.
Underlying DBMS error [Error executing stored procedure
sde.instances_util.check_instance_table_conflicts::ORA-00942:table or view does not exist].
If I'm trying to import any data the same error.
I have confirmed all privileges with other working database.
Need, expert advise.
Amit
VinceAngelo
Esri Esteemed Contributor
You should probably contact Tech Support.
- V
