Error when switching back to three-tier connections.
1072
09-19-2011 10:22 AM
BrettBlankner
I'm having trouble changing our services from direct connections to three-tier. I get error messages when doing so. Can I get some guidance?  I change the connection properties to port 5151, and that should be all, right?
VinceAngelo
Esri Esteemed Contributor
Direct Connect doesn't requrire a hostname, so changing the port often isn't enough.
What version of ArcSDE are you using?
Is the application server service running?
What exact error messages are you receiving (as text, preferrably)?
- V
