Error in the some st_geometry functions (ORA-28579)
6522
07-09-2014 02:27 PM
MarceloEdy_Peinado
Hello,
I have problem when I try to use some st_geometry functions.
One of them is the st_buffer()
In the resource center there are a example for use it (st_buffer):
http://resources.arcgis.com/en/help/main/10.1/index.html#/ST_Buffer/006z0000003z000000/
But, look that happened when I try to run the query using sqlplus:
SQL> SELECT sa.id "Sensitive Areas", hs.name "Hazardous Sites"
  2  FROM sensitive_areas sa, hazardous_sites hs
  3  WHERE sde.st_overlaps (sa.zone, sde.st_buffer (hs.location, 0.01)) = 1;
ERROR at line 1:
ORA-28579: network error during callback from external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 325
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 1213
The curious is that others functions like st_relate works fine!
Anyone can help me?
ArcSDE 10.1 for Linux
Oracle 11g (11.2.0.3)
Thanks and regards.
Marcelo E. Peinado
Optimus GIS & IT Solutions
DonOpgenorth
I've moved your post into the  Managing Data space.  You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
NicoleSchleifer
I'm having the exact same issue.
Did you find the resolution?
