error direct connect Oracle 11G + SDE 9.3.1
969
06-27-2011 01:54 PM
Arturo_FranciscoAcosta_Bazán
Hi V
try to make a direct connection to my oracle database on another server that but I get this error from the server containing the sde :
failed
server library could not be loaded
the connection direct is
server    --------
service   sde:oracle11g:/;local=sdeorcl
user       gisadmin
pass      gisadmin
anthonysanchez
is the oracle client on your remote server 32 or 64 bit?  Direct connects from arcgis require the 32 bit client since they are 32 bit apps.
Anthony
Is oracle 64 bits , then that is the problem?
